Part Number: BQ35100
from the bq35100 Technical reference manual:
Sequence Perform the following calibration sequence during battery pack manufacturing process:
1. Perform Voltage Calibration. 2. Perform CC Offset. 3. Perform Board Offset. 4. Perform Current Calibration. 5. Perform Temperature Calibration
Now if you look at the laid out algorithms some say enable cal mode other omit.
Can i do:
Cal enable
Cal voltage
Cal disable
Cal enable
CC offset Cal
Cal disable
Cal enable
Board offset Cal
Cal disable
Cal Enable
Current Cal
Cal Disable
Cal enable
Temp Cal
Cal disable.
Or can I do
Cal Enable:
voltag cal
cc offset cal
board offset cal
current cal
temp cal
Cal Disable
