TPS2552-1: Negative power supply connect to the input
Part Number: TPS2552-1
Sir
According to page one of the datasheet, the typical application of TPS2552-1 is USB power delivery with reverse voltage protection.
Our evaluation recently is the reverse input polarity protection.
We would like to understand whether it does matter if the input of TPS2552-1 is connected to the negative power supply.
Is TPS2552-1 suitable for the application of input polarity protection?
Or any alternative could advise us in your expert opinion.
Any comment is welcome.
Ben
  • Hi Ben,
    In this case, reverse voltage protection refers to cases where VOUT > VIN.  I do not expect any of our USB power switches will protect against an inverted supply input.  For input polarity protection, I suggest looking at a separate circuit such as an ideal diode/ideal diode controller.
    Eric
