TPS7B68-Q1: PG, WDO pin information
Part Number: TPS7B68-Q1
Hello LDO team,
My customer (Hitachi Astemo) start schecking datasheet of this device.
I got some question about PG, WDO pins.
Q1) To set resistor value, please share the max/min pulldown current of PG & WDO respectively.
Q2) They want to tigh PG/WDO together and connect to MCU, please propose example circuit.
Q3) There is a thermal pad at bottom side PKG. Is this pad connected to GND internal PKG or floating?
ti
    We do not data for this, but the pulldown resistance is normally several hundred ohms, and the range of resistance values is 10k~100k.
    At minimum they can just tie the PG and WDO pins together and use a single pull up resistor. Otherwise they can use 0ohm resistors at each pin and include pads for separate pull up resistors.
    The die attach is electrically conductive, so the thermal pad is connected to PBKG.
    Nick
