Part Number: LMR38025
Other Parts Discussed in Thread: LM70880-Q1
Hi
I am looking for a buck converter
60V input
48V output/600W !
and a anther convertor
for
30-48V input
24V output/300W !
Hi
60V input
48V output/600W !
for
30-48V input
24V output/300W !
Hi Yoni,
I assume you want to have monolithic buck converters. If so, I recommend using the LM70880-Q1. The part is capable of parallel operation to generate the 12.5A needed at 24V. You would need another parallel setup to generate 12.5A at 48V output.
We also have the LMQ644A2-Q1, but its ABS MAX VIN is 42V.
Ben
Hi Yoni,
I do not have a particular schematic for the LM70880-Q1 as the datasheet is still being worked on (a limited version is online) but you can look at the LMQ644A2-Q1 datasheet on page 24 to get an idea how two LM70880-Q1 will meet your design criteria.
Ben
Hi Yoni,
The parts are available and are in preproduction status. Yes, they are for sale.
https://www.ti.com/product/LM70880-Q1#order-quality
Ben
