TPS7A4501-SP: SHDN Vin_low,max details
Part Number: TPS7A4501-SP
During our analysis, an issue has been raised while driving the SHDN pin at corner cases. I would like to know a bit more what could influence the Vin_low,max parameter? Do you have some graphic to provide?
Thanks for your help
Kind regards
Sylvain
  • Hi Sylvain,
    Can you clarify whether you're talking about the max value of the minimum VIN parameter, or either of the SHDN thresholds? If it's possible for you to describe the behavior you're seeing, I may be able to provide better feedback.
    Sarah
