We have an electronics with a backup circuit based on a TPS61094DSSR.
The electronics is working properly but now we wanted to increase the capacity of the backup system so that it can operate with more output current and a single 2.7V/25F capacitor is not enough.
To obtain the desired current, we need the capacitor voltage to be higher and I would like to know if the TPS61094 component works correctly with 5.5V type capacitors as it does not have any pins for balancing control.
