hello
I received feedback from your team regarding gold plating thickness for this part to be 70-225uin. in my research i found 50uin to be more standard. and 100uin to be used on connector contact with requirements of 10000 connection cycles plus.
can you please double check the 70 to 225uin. value provided and double check. I'm doing an analysis on all my components and TI is the only supplier thus far to specify such thick gold plating.
thank you for your time.
