TPS25750: TPS25750D
Part Number: TPS25750
Other Parts Discussed in Thread: TPS25751
Is TPS25751DREFR a 1:1 drop-in replacement for TPS25750D?
When will we've samples of TPS25751DREFR
Thanks and bye
Hanno
  • Hi Hanno,
    Thank you for reaching out!
    Yes, the TPS25751D is a direct follow-on to the TPS25750. The TPS25750 and TPS25751 are pin to pin compatible with one another. Please see the following FAQ
    I will get back to you in regards to the samples.
    Aya Khedr
  • Hi Hanno,
    We are actively working with our TI sample store team at the moment to get more units stocked within the store. If you send me a private note, we may be able to supply material outside of the sample store depending on what their needs are.
