Other Parts Discussed in Thread: EV2400, , BQSTUDIO
Hi I have a battery issue where new batteries produced consume 83uA in supposed sleep mode. When i connect the to the BQ76942 using the EV2400 i can read SLEEP is enabled. When I unseal and full-unseal the device to read the settings the battery will change current consumption to the intended 24uA. All batteries unsealed will change to draw LESS current when unsealed than sealed. Why is this? Is there a configuration which only affects the sealed mode?
When in unsealed mode the battery will flicker between 24uA and ~110uA for about 1-2min before stabilising at 24uA. Is the 83uA read some sort of average value read in sleep mode? Why won't it stabilise in sealed mode then?
Kind regards Fabian
