Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS61088-Q1: low VIN capability in 2 cell battery
Part Number: TPS61088-Q1
Other Parts Discussed in Thread: TPS61088
Hi Expert,
The recommended operating conditions of TPS61088 is 2.7V to 12V. My customer would like to check if 61088 can maintain 8V/6W output(10 minutes minimum) when VIN drop to 1.2V after 61088 start up.
I saw there have a reference design(https://www.ti.com/lit/ug/tiduet0a/tiduet0a.pdf). In this design 61088 can maintain the 8V/1.6A output when VIN drop to 2V. 2V is enough for 3 cell BUB. But in 2 cell NiMH battery, the minimum battery voltage will drop to 1.2V.
Thanks!
Ethan Wen
