Hello E2E Experts,
Good day.
Is there a technical reason why a 470 Ohm resistor was used?
Data Flash Programming Using the EV Software (Rev. A (ti.com)
TI-CSC
Hello E2E Experts,
Good day.
TI-CSC
For charging we recommend checking the data sheet of the battery you are using to make sure you are not charging over the recommended charging current limit. We recommend that you charge using a rate of C/2. So the charging current for your battery would be 3225 mA.
Nick Richards
