I would like to have a design provision for a snubber circuit on the switching node. To especially determine the power rating and size of components, one key factor is the switch output capacitance. This is not listed in the datasheet. Prior to putting my design through PSPICE (I do not have it installed yet), I'd like to at least work through Excel to determine reasonable estimates for placeholders. Once the design is in place, the supply will be instrumented and final values determined.
Can you provide a typical value, and the range across temperature of the internal FET Coss?
Thank you.
Steven
