Hi team,
Need design support
We are using TPSM84624MOLR part to generate the Output 3.5V/ 6amps. With input voltage of minimum is 4.75V and Max is 5V. Please share your suggestion details.
And also, please consider the negative overcurrent limit of TPS84624 and confirm for my above-mentioned output design requirement.
Thank you
