Part Number: LM5123-Q1
Other Parts Discussed in Thread: LM5121
Hi Harry,
Does the UVLO_EN pin allows when connected to a HOST (MCU) in addition to its resistor divider, to shut-down the LM5123-Q1 when pulled low by the HOST? Is it, as a result of shut down, turns off the HO and LO outputs in a way that the two high and low FETs are turned off and no voltage transferred to the Drain of the high FET?
Ohad
