TPS7H6023-SP: Referece pspice model (TPS7H60x3_trans.dsn) behavior
Part Number: TPS7H6023-SP
Very high current measured on highside driver "ASW" terminal. Is it correct behavior ?
I found it on the original TPS7H60x3_trans.dgn simulation on PSPICE for TI.
The measured procedure is following.
1. Exstract the reference design and open in the PSPICE for TI.
 Filename which I downloded "snom790.zip" from
"">www.ti.com/.../TPS7H6023-SP
2. Select .\tps7h60x3_trans.dgn\BUCK folder and Choose "Make root".
3. Double click "page" and open "Open-Loop Buck Schematic"
4.  Select  "New simulation profile", add name as "open-loop-buck-sim", and press "Create" button.
        Change "Run To Time" box to "1ms" and press "OK" button.
5.  "Run P-SPICE"
6.  Add current probe on "ASW" terminal of TPS7H60X3_TRANS and check the current.
7. I measured the following wave form.
8. Is it correct behavior ?  I found more than 80KA of spike current on the terminal.
Best Regards.
