Other Parts Discussed in Thread: BQ25628
Is there a way to activate HSFET to power loads with PMID pin?
Based on the Table 5.1 of BQ25628E datasheet rev. 02/2024, this IC dont have OTG function. In the same datasheet I can't found any way of activate this PMID output. Can you confirm that is possible to use PMID pin and how activate ?
Hi Gabriel,
Please allow me to clarify. The BQ25628E does not have OTG function. When a valid VBUS is present PMID is connected to VBUS, but there is no way to turn on HSFET in battery only operation.
The BQ25628 (non E version) does have OTG function where you can enable OTG function via I2C to power loads at PMID pin. Please see BQ25628 datasheet section 8.3.6 for further details.
Garrett
Ok. My first question was about BQ25628E which is the part I am using. Now it is very clear. thank you!
