The TI E2E™ design support forums will undergo maintenance from July 11 to July 13. If you need design support during this time, open a new support request with our customer support center.
BQ51025: Best Qi Charger and Receiver for 8W Embedded Application
Part Number: BQ51025
Hi there, on a drone, I need to get from the stationary motor side into the rotating propeller with 8W of power and low bandwidth bidirectional communications. There is a microcontroller on each side already with TTL serial, I2C or SPI capability. USB is not really desired, but may be useful during development only. While I don't really need Qi it might be the best solution. What recommendations and/or suggestions would you make for my application? I am totally open to non-Qi or older Qi solutions as well assuming I can get the power, bidirectional communications and continued supply chain. There is no battery in the propeller.
Thank you,
Alan
