Other Parts Discussed in Thread: AM3352
When powering up, the "SWIO" voltage may not be output about once in 1000 times.
I am using a combination of AM3352BZCZ80 and TPS65910A31A1RSLR.
Is there anything that could be causing the startup failure?
Please let me know if there is anything that needs to be checked.
-Other voltages are output normally.
-When the output is NG, other power supplies also start up faster than usual. At this time, the rise slope is distorted.
-Forcing pin 1 of the TPS65910 to low will restore "SWIO".
-Pins 1, 40, 37, 45 of the TPS65910 are connected to the AM3352.
Pin 33 "PWRON" is open.
*I am not fluent in English so I am using a translation. Please excuse any strange sentences.
Thank you in advance for your consideration.
