TPS7A83A: Output cap selection
Part Number: TPS7A83A
Hi Team,
I see below comment in datasheet.
And my question is that how to select the appropriate output cap to get proper system stability? As I know, LDO is one pole architecture. Does zero generating by output cap ESR improve the system stability?
Roy
  • Hey Roy,
    Especially for some of our older devices, minimum ESR was essential to maintaining LDO stability. Our newer devices have a more robust compensation network, that allows them to be compensated with low ESR capacitors, like ceramics.
    The internal ESR forms a zero with the output capacitor whose frequency can be calculated from: ZESR = 1 / (2 X π X ESR X COUT).
    The zero increases the phase margin at the calculated frequency to make the device more stable across frequency.
    You would know what type of compensation network you need based on a gain and phase margin analysis of your system and the system requirements.
    This article may be helpful in aiding your understanding: AN-1482 LDO Regulator Stability Using Ceramic Output Capacitors (Rev. A) (ti.com)
