Hi Team,
I am using SN1701022 controller IC.
In Fusion Power Designer Software, Monitor GUI we are getting correct steady waveform for output voltage of 1.8V
But when we checked in oscilloscope, it is showing Spikes in output voltage of P1V8_AUX (1.8V). I am attaching the image of error below which is captured in oscilloscope.
Can this be corrected using Load Line resistor value in Fusion GUI?
I found in TRM, some commands like MFR_SPECIFIC_07, VOUT_DROOP, and MFR_SPECIFIC_14 can be used to adjust output voltage in such cases.
Will this work in our case? Will that solve the voltage spike issue that we are facing?
For VOUT_DROOP in Hex, it is corresponding to particular DC load line resistor, so how to select this value for particular application?
Siddhi
