LMQ644A2-Q1: Current sharing possible?
Part Number: LMQ644A2-Q1
Other Parts Discussed in Thread: TPS54560B-Q1
Dear TI-support team,
is it possible to connect two or more LMQ644A2-Q1 ICs in parallel in order to get more output current?
The output is current-mode controlled and the COMP pin is available so two COMP pins and the FB pins could be tied together I think. A similar TI application is described here: https://www.ti.com/lit/an/slva389/slva389.pdf
Thank you
Best regards
Lyto
