Other Parts Discussed in Thread: BQ25883, BQ25882, BQ25306
Need a BMS IC with, overvoltage, undervoltage, overcurrent, short, and reverse connection protection features for 2S charging, plese help.
Hi thanks a lot for the reply however, the IC suggested by you seems to need a microcontroller, I am looking for an IC that does not need a microcontroller, it should charge two 18560 li-ion batteries kept in series battery upto a certain voltage then stop charging, should cutoff the battery from from load when the battery reaches a certain voltage level, and also protect from overcurrent
Please check BQ25306 standalone charger at https://www.ti.com/lit/ds/symlink/bq25306.pdf
Ning
