Part Number: BQ76940
Other Parts Discussed in Thread: TIDA-00255
Hi there,
I'm designing a BMS using TI IC BQ76940 but I'm failing to understand how DSG and CHG pins works in that. I used reference deign given by TI and with this design when load is connected to battery there is an voltage of 3.2 at DSG pin which should be driving MOSFET but MOSFET used in TI design has a Vth(thresh hold voltage) of 4.1V so 3.2V is not sufficient to drive MOSFET
I would like to know in what logic IC is detecting load and charger connections.
Thank you
