LM2104: What is the tolerance on the deadtime?
Part Number: LM2104
The LM2104 has a fixed internal deadtime specified as 475 typical. There is no min or max deadtime or deadtime tolerance specified. What are the min and max deadtime for this part?
  • Hey Dennis,
    Thank you for reaching out to TI with your question regarding the LM2104.
    We do not specify min or maxes on this datasheet parameter so therefore I don't have numbers to provide to you for that. Typically, when we do not include a min/max spec it is due to the typical spec holding true throughout our testing and it not having enough variance to warrant an added spec. So, the 475ns deadtime should be as expected for operation with this driver.
    Let me know if you have any further questions.
    Thank you,
    William Moore
