I am searching for an unencrypted spice file for TPS259824ONRGE. Thank you for your help!
Collin
Collin
Hi Collin,
I hope this helps you. Please let me know if you have any follow up questions.
Click resolved to close this thread.
TPS259824ONRGE_PSPICE_TRANS.zip
Arush
Hello, I used this model file to create the LTspice part, but when I run the simulation, it gives a bunch of errors related to the coding in the .lib file. Do you know how I can get rid of this error log message?
Error Message:
Circuit: * C:\Users\collin.argo\OneDrive - General Dynamics Mission Systems\Jobs\Tang\Local Power Supply Unit\LPSU LTspice Model\TPS259824O Modeling\TPS259824O_Model.asc
Questionable use of curly braces in "b§e_abmgate1 yint1 0 v={if(v(a)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate2 yint3 0 v={if(v(yint2)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](yint2)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate2 yint3 0 v={if(v(yint2)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](yint2)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}}&v(c)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh))&v(c)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}}&v(c)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh))&v(c)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}|v(b)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))|v(b)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vss}},{{vdd}})}"
Error: undefined symbol in: "if([v](a)>((vthresh)),((vss)),((vdd)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}|v(b)>{{vthresh}}|v(c)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))|v(b)>((vthresh))|v(c)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}}&v(b)>{{vthresh}},{{vdd}},{{vss}})}"
Error: undefined symbol in: "if([v](a)>((vthresh))&v(b)>((vthresh)),((vdd)),((vss)))"
Questionable use of curly braces in "b§e_abmgate yint 0 v={if(v(a)>{{vthresh}},{{vdd}},{{vss}})}"
Warning: Multiple definitions of model "nmos01" Type: Mos1
Warning: Multiple definitions of model "d_d1" Type: Diode
u1:_u3_u14:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u3_u21:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u3_u11:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u11:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u13:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u12:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u6:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u9:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u7:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u5:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u8:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u10:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u100_u7:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u2_u100_u10:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u4_u20:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u17:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u15:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u10:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u18:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u14:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u16:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
u1:_u5_u13:d_d1: Emission coefficient, N=4.22381e-312, too small, limited to 0.1
Per .tran options, skipping operating point for transient analysis.
Ignoring empty pin current: Ix(u1:en_uvlo)
Ignoring empty pin current: Ix(u1:gnd)
Changing Tseed to 1e-08
Changing Tseed to 1e-10
Heightened Def Con from 0.00263704 ++++++++++++++++++++++++++++++++++++++++++++++++++Fatal Error: Analysis: Time step too small; time = 0.00263704, timestep = 1.26473e-18: trouble with node "u1:_u5_u50:ch"
Hi Collin,
I am trying to get access of LTspice on my pc. Once I get it, I will try this.
Arush
Arush,
I noticed I had LDSTRT pin pulled high instead of grounded. Also changed my LTspice solver to "Normal" instead of "Alternate", and I was able to run the simulation. All good now!
Thank you,
Collin
