TPS65994AE: HLK TEST Fail,pd f/w will always send out the battery charger state causing ppm fail
Part Number: TPS65994AE
Hi Raymond,
We test HLK TEST Fail,Fail Item:USB Type-C UCM Disable Enable Test
pd f/w will always send out the battery charger state causing ppm fail,Is there any option to modify the settings of pd f/w? can stop sending battery charger state all the time.
Log As attach file,Thanks
3618.USB Type-C UCM Disable Enable Test_0617.htm
Marty
