InterruptStatus() is listed as a data command read only...but scanning through the documentation lower it says it reports info on macdata()???
If it does the later then you likely have to write to it. Which is it?
Currently doing a read and getting the wrong/unexpected value when interrupt is firing.
UPDATED: It does work like a data command and it is readable like one. The macdata() description is misleading, not sure what it's talking about.
