UCC28C42: OCP LEVEL discussion
Part Number: UCC28C42
Hi Team,
 i would  like to check with you why the OCP pot will decrease during high temp?
 we found some use case when work at high temp ,it is more easy to triggers the OCP .it there a issue relate to IC itself or any peripheral ?
 tks for the checking.
  • Allen,
    Would you please share more information about this? From what-to-what value OCP decreases a high temp? What high temperatures was the device tested? Could you please share schematic of the test setup? How many devices have you tested? Did you find the same issue on all the tested devices or just some of them?
    That information will help for better debugging
    Thank you
