Other Parts Discussed in Thread: TPS565201, TPS563201,
I need to update the design for a device that requires 15V at 20W:
- The design currently uses the NRND AP3371 to negotiate PD 15V at 20W
- POWEN (AP3371 pin23) is connected to EN of two buck converters (TPS565201 pin5 and TPS563201 pin5)
- power from VBUS does not connect to any other circuits
I am considering switching to TI for this part (as I have done with most other parts). I have two questions:
- Can you recommend which output from the TPS25730 I should use to control the buck converter?
- Is there a different simple TI part for USB sink PD in TSSOP or similar package? CH224K-style package has advantages for me.
