I've been using ULN2003ADR combined with MCU for digital applications and I wanted to know how well it could perform in an analog circuitry as the one below (hard clipping distortion effect).
I'd like to switch between several set of diodes (depending on diode voltage drop, distortion color is different) without using a switch or a signal relay.
The idea is to connect to ground the diode set I want to use and let the other ones deactivated.
How well would the ULN2003ADR perform in this scenario and could there be any noise coming from MCU injecting in the audio signal ?
If any of my point is unclear please let me know.
Thank you.
