Could you help to confirm when the customer only modify the value of Qmax, whether the check sum will be modified at the same time?
Hello Fabio,
We do not have documentation, but I just asked firmware team and they told me that AllDFSignature is a user programmed value that can be used in production to verify that data memory was programmed correctly. The user can define their own checksum value for the entire data memory and that can be programmed as the AllDFSignature. Then in production, the checksum can be calculated after programming and then compared to the AllDFSignature.
Nick Richards
