TLC77: Datasheet error of TLC7705QD
Part Number: TLC77
Greetings
Working with device TLC7705QD came across an error on the data sheet SLVS087M Revised March 2012
VIT–
Negative-going input threshold voltage, SENSE(2)
 VIT- is measured in mV for revision M of the Data Sheet.
on Revision L of Data Sheet SLVS087L unit is represented as Volts.
Can you confirm what data sheet is correct, or what Unit is correct.
  • Hi Winsbert,
    I also checked the previous datasheet (Data Sheet SLVS087L) and as you mentioned the unit's of Negative-going input threshold voltage  ( VIT -)  was defines as Volts.
    Thanks for bringing this to our attention. I will check with my team to fix this typo, and please consider the correct units of  ( VIT -) as Volts.
    Sila
