Dear Engineers,
I want to use this reference design (PMP40488) for one of my application.
I noticed if I used coupled inductor for L3 and L4 I will get better performance and the value of the positive rail and rail will be closer to each other:
Based on the test report there is a little bit difference between positive and negative rail:
Based on the bill of material of the reference design, it seems, they have used two separate inductors for L3 and L4 and not a coupled inductor:
I wonder If I use couple inductor the results will be different? or I can not gain that much? what is your suggestion should used the same BOM for having a reliable performance?
