TLV772: About Characteristics graphs.
Guru 11325 points
Part Number: TLV772
Other Parts Discussed in Thread: TLV773
Hi team,
I'd like to know bellow information.
1 : Recommend FB resistance value.
      I'd like to use 15kΩ(R2) because I want more small quiescent current for FB resister.
2 : Could you share graphs?
     Output CurrentーDropout Voltage / Output CurrentーQuiscent GND Current
BR,
Kengo.
  • Hello Kengo,
    1) What output voltage are you wanting to use? The equation to calculate output with the feedback resistance network: Vout = Vfb * (1 + (R1/R2)), with Vfb = 0.6V
    You may also need a feed forward capacitor for this device, but that has not be verified as of yet. More information on the feedback network will be given at the release early 2025.
    2) We are unable to provide graphs at the current moment as this device is still pending a release to the market. This device should be released closer to early 2025, and data specification will be available then. Data should be similar to the TLV773 device.
    Hannah
