Other Parts Discussed in Thread: LM5158
Hi team,
Could you help check why I can't design as below setting?
Lillian
Hi Lilian,
Thanks for using the e2e forum.
I am sorry that you got an error using the webench tool.
Is there are preferred topology you want to implement?
LM5001 is a boost converter, but can also be implemented as SEPIC or Flyback.
As your Vout spec is always lower than Vin, you can also use a Buck converter.
If isolation is required, you can use a flyback design using LM5158.
Niklas
