BQ76940: VAR-SOM-MX6 SRRC TEST in China
Part Number: BQ76940
Hello,team:
This is Stephen from Precor Incorporated, We are using your product Varicite VAR-SOM-MX6 Freescale i.MX6TM - based System-on-Module (SOM). We install it on our consoles.
The problem now is that we need to do SRRC testing in China, but the testing agency thinks that the radio transmission frequency range of the prototype we provided is toowifi主板.docxde, and they cannot conduct relevant tests (including strength test and anti-interference test, etc.), so we need your support to enable us to provide a radio module that meets their requirements; if possible, you can send someone to contact my email: stephen.shi@precor.com. If you can't provide the module, you'd better tell us how to make a fixed-frequency module, including what hardware and software are needed, and the relevant steps, thank you
  • Hi Shi,
    Our parts are use on multiple applications and are designed to pass different types of certifications that varies significantly based on industry and location. It is the end-customer responsibility to work with their certification agency to assure their systems meets the needed requirements to meet that test, etc..
    On your question you mentioned the Varicite VAR-SOM-MX6 which is not a TI part. Please reach out to the appropriate company for your question.
    You also selected the BQ76940 as a part number, If you have a specific question about the BQ76940 functionality or behavior please post a different post with the same, and we can provide the needed support about the BQ part. For systems level design questions or how to pass your requirement,  you will need to work with your certification agency and figure out the steps and requirements you need to implement on your system design.
    Arelis G Guerrero
