I understand how to use the OSEL, VCHG, and ICHG pins.
1-) Is it possible to set values other than the 16 values provided in the device datasheet (Table 7.1, Table 7.2, and Table 7.3)?
2-) If possible, does this apply to all three pins?
3-) If it is possible, could you share the formulas to obtain the desired value based on the resistance? (I assume there is a different formula for each pin. I would like the formulas for all three pins.)
