Other Parts Discussed in Thread: TPS65224-Q1
Hello, team.
We used the TPS65224-Q1 to supply power to the processor's various rails. We were using the TPS6522x Evaluation Module User's Guide as a design reference, and the only difference is that Buck 4 is utilized for 3V3 supply requirements. Is it possible to explain the procedure used to select the output capacitor for a given BUCK output, or may we assume it to be the same as the other BUCK outputs, such as 47uF, 22uF, 2.2uF, and 0.1uF?
