Other Parts Discussed in Thread: LM431
hello. I am designing a sic gate driver using UCC5390. I want it to generate +18V, -3V.
So the input voltage +12V is fixed and I want to use this voltage to generate +18V, -3V. Is there any good solution?
I need to change the circuit on the left and would appreciate if you could share your recommendations and schematic. I have heard that there is also a way to use a Zener diode.
Thank you.
