Other Parts Discussed in Thread: UCC29002
Hello TI support personnel,
I am using the UCD3138ALLCEVM150 circuit board.I encountered the following problem while using Fusion Digital Power Studio to configure my circuit board, and I hope to receive your help.
1.After burning the code, the circuit board was able to run normally, and the output was measured to be normal using a multimeter. However, the number I read in the GUI did not match the actual value.
2.I want to configure the relevant parameters in the "Configuration" column, but I cannot change the data. My operation is to change the value of a certain item and click "Write to Hardware". I want to know if this is the correct operation?
