Other Parts Discussed in Thread: TPS25751
I would like to know the best way to disable the Power Path in case of a Power Capability Mismatch when using TPS25730.
TPS25730 has a pin (CAP_MIS) that is toggled when a Power Capability Mismatch occurs. In our application, we will have a 4-Switch Buck-Boost (BQ25756RRVR) connected to TPS25730.
Is the best way to do it by disabling the Buck-Boost using CAP_MIS pin?
In case of TPS25751, there is an internal register that can be configured to disable the Power Path in case of a Power Capability Mismatch, but TPS25730 does not have this capability.
Thank you for your support in advance.
Jaime
