Other Parts Discussed in Thread: BQ25731, BQ25730, , TPS25751
I was using the TPS25750D with the BQ25731. When using the application customization tool, the bin file generated does not work. When I posted about this, it was later suggested to use the TPS25751D instead. This part's application customization tool still does not support the BQ25731, though a bin file for use with the BQ25731 was supplied and it worked. This issue is that we are currently going into production and the TPS25731D is out of stock practically everywhere. In this regards, is it possible to generate a working bin file for the TPS25730D working with the BQ25731?
