TPS543C20A: Switching Noise
Part Number: TPS543C20A
Hi Britton,
Another question on this part. We noticed on our current switcher that the ringing from the switching wasn't negligible. Do you have any recommendations on how to reduce this . The data sheet mentions using both a snubber and special high frequency bypass caps.   Do you think the bypass caps would be enough?
Matt
  • Hi Matt,
    A 2.2nF-10nF bypass capacitor placed as close as possible to the PVIN pins is usually enough to reduce ringing to an acceptable level. In applications with high VIN, a snubber can also be used but is not usually needed. It is a good idea to add a placeholder for the snubber components in your layout for future-proofing,  but is not a requirement to reduce the sw ringing as the bypass capacitor will do most of the heavy lifting.
    Britton
