Hi Ti team,
I have some droughts regarding turn on the chip and charge pump
- Can I turn on the BQ76942 chip by providing 12V using bench-top (without cell voltages) across the BAT and VSS pins and also pull down the TS2 (for wake-up) and RST_SHUT?
- Can I OTP the chip without connecting cell voltages or without a battery?
- How does the charge pump circuit work? (Datasheet tells only about configuration of adding BAT voltage + 11V or 5.5V)
- Is there any block internal diagram for the charge pump?
Janardhan Babu M.
