Other Parts Discussed in Thread: UCC28950
- Been looking at LLC and was set to go that way, but I noticed you had suggested Phase Shift for higher wattages. What would you suggest ? We had lots of issues with the UCC28950 at 3kW...
And, the UCC28950 controller we used would go chaotic at higher current outputs/high noise levels. The FET drive signals were turning ON and OFF not in accordance with the data sheet.
For higher power applications above 1 kW, generally the phase shifted full bridge (PSFB) is a better choice. The UCC28950 has been used in many applications at 3 kW.
I am sorry that you have had issues with designing PSFB converters in the past. The following application note goes through the step by step design process of using the UCC28950 in a PSFB. There is even a link to an excel design tool in the application note that can be used to setup the controller and select power stage components. I believe this information will help you in the design process and hopefully help resolve any design issues that you have had in the past.
https://www.ti.com/lit/pdf/slua560
Customers have found that having a working design for comparison can help in the debug process of there design. We dot have a 600 W evaluation module that you can order from ti.com that uses the UCC28950. The following link will bring to this evaluation modules User Guide.
Thank you for interest in Texas Instruments (TI) products. If you have a related question, please click the "Ask a related question" button in the top right corner. The newly created question will be automatically linked to this question.
