Hi TI partner,
Since we are about to conduct the PD3.1 Compliance test using the TPS25751DREFR, could you please provide the TI VIF (Vendor Info File) for our upcoming testing?
Thank you.
Hi TI partner,
Thank you.
Hi Showfen,
You can generate an VIF XML file by using the export setting here:
Please note this VIF file is intended as the starting point, additional changes to the VIF file is required based on your specific application. You can download the VIF editor from the USB IF webpage linked here: https://www.usb.org/document-library/usb-vendor-info-file-generator
Let us know if you have any further questions or concerns!
Thanks and Regards,
Raymond Lin
