BQ79616-Q1: Slave does not go to sleep
Part Number: BQ79616-Q1
Other Parts Discussed in Thread: BQ79616
Hello there,
I am working with a BQ79600 and BQ79616 System, this works most of the time but sometimes i get the issue that one slave does not shutdown after the communication time out. I tried also implementing a Shutdown or Hardware Reset Ping in the Boot Sequence but that does not resolve this issue either. The only solution that works is to disconnect the slave from Power Supply and reconnect it then it works just fine.
Thanks for your help in advance
