Part Number: BQ77PL900
I designed a schematic using the BQ77PL900 for use with a 10s LiPO battery.
Could you take a look to make sure it looks okay?
Marcelo
Marcelo
Hi Marcelo,
Yes, I definitely take a look! I am not seeing anything attached in your message. If you could attach a pdf of the schematic I can gladly look over it.
Thomas Rainey
Hi Marcelo,
I noticed there are no filtering capacitors on the VC pins. I would definitely add .1µF capacitors in between the VC pins.
For a guide on design I recommend using the bq77PL900EVM-001 (Rev. B) as reference.
Thomas Rainey
