TPS62130: Outputs Constant 1.2V , No Switching Happens
Part Number: TPS62130
Recently,
During Board Rework, We removed the Resistor to GND at FB pin of regulator and powered on the board, The regulator stops working, it outputs Constant Voltage,
Later we mounted the Resistor Back, but Still it is Outputting 1.2V, No Switching Happens. Does the Regulator got Damaged???
If Regulator Got damaged, Could you explain, Why it Happened??
