TPS7A20: AC signals sent to the LDO input to generate the PSRR tables
Part Number: TPS7A20
Hi Team,
For the data sheet of the TPS7A20 LDO (SBVS338G), what is the amplitude of the AC signals sent to the LDO input to generate the PSRR tables and graphs?
Roy
    Thank you for your question.
    I have reached out to one of our validation engineers about what the line injection was set to for the PSRR graphs.
    I will let you know as soon as I hear back.
    Hannah
  • Hello Roy,
    After looking into this more, our validation engineer has determined that the line injection was not well documented enough to know what this was set to when producing the PSRR tables and graphs.
    Validation did state that it is safe to assume that the injection voltage was =<100mV peak to peak, but we do not know for sure.
    Hannah
